In this guide you will learn how to replace your Asus Vivobook X540SA-BPD0602V's Hard Drive. Replacing your laptop's Hard Drive is a necessary step in upgrading the devices memory.
Power down the laptop using the device's power button in top right corner of the keyboard. Ensure that the device's power cord is disconnected.
Flip the laptop over so the back panel is displayed.
Using a Phillips #1 screwdriver, remove the ten screws from the back panel.
Remove the two battery screws (15.6 mm)
Two top corner screws (12.5 mm)
Six case screws (9.7mm)
Flip the laptop back over and open it, revealing the screen and keyboard.
Using the blue plastic opening tool, wedge and loosen the seal all the way around the edges. Carefully lift up the keyboard panel.
Observe where the ribbons connect to the motherboard, there are two connections. Each connection has a black clamp. To remove the ribbon, lift the black clamp up to disconnect it.
Very carefully, remove the batteries with the blue plastic iFixit opening tool. Focus removing the battery near the highlighted area.
The Disk Drive is located within the upper right hand corner of the laptop.
Using a Phillips #0 screwdriver, remove the two screws (5.6 mm) around the disc drive.
Use the Phillips #00 screwdriver to remove the two screws (2.7 mm) on the side of the disc drive fastener.
After removing the seven screws, lift the metal fastener from the disc drive with the plastic opening tool.
Slide the disc drive to the right, removing it from the laptop case.
The Hard Drive is located in the bottom right hand corner. It should be the device covered in black foam.
Using the Phillips #0 screwdriver, unscrew the four (5.7cm) screws around the hard drive.
Using the blue plastic opening tool in the iFixit tool kit, slide the hard drive to the right to remove it from the case.
