Asus VivoBook X540SA-BPD0602V Disc Drive Disassembly
  1. Asus VivoBook X540SA-BPD0602V Disc Drive Disassembly, Keyboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Power down the laptop using the device's power button in top right corner of the keyboard. Ensure that the device's power cord is disconnected.
  2. Asus VivoBook X540SA-BPD0602V Disc Drive Disassembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the laptop over so the back panel is displayed.
  3. Asus VivoBook X540SA-BPD0602V Disc Drive Disassembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #1 screwdriver, remove the ten screws from the back panel.
    • Remove the two battery screws (15.6 mm)
    • Two top corner screws (12.5 mm)
    • Six case screws (9.7mm)
  4. Asus VivoBook X540SA-BPD0602V Disc Drive Disassembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the laptop back over and open it, revealing the screen and keyboard.
  5. Asus VivoBook X540SA-BPD0602V Disc Drive Disassembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the blue plastic opening tool, wedge and loosen the seal all the way around the edges. Carefully lift up the keyboard panel.
    • When lifting the keyboard panel, do not lift it all the way as the two connection ribbons to the motherboard must be disconnected.
    • It is recommended to break the seal of the case starting at the upper corners closest to the display monitor .
  6. Asus VivoBook X540SA-BPD0602V Disc Drive Disassembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Observe where the ribbons connect to the motherboard, there are two connections. Each connection has a black clamp. To remove the ribbon, lift the black clamp up to disconnect it.
  7. Asus VivoBook X540SA-BPD0602V Disc Drive Disassembly, Battery: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Very carefully, remove the batteries with the blue plastic iFixit opening tool. Focus removing the battery near the highlighted area.
    • The batteries should all be connected to one another and come out of the device as a single unit.
    • Be careful not to rip any of the black plastic covering the batteries. Exposed battery parts can lead to explosions. If the case is ripped, re-wrap them, or properly dispose of them. Do not reuse them.
  8. Asus VivoBook X540SA-BPD0602V Disc Drive Disassembly, Disk Drive: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The Disk Drive is located within the upper right hand corner of the laptop.
  9. Asus VivoBook X540SA-BPD0602V Disc Drive Disassembly: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #0 screwdriver, remove the two screws (5.6 mm) around the disc drive.
    • Note which screws go where. The two smaller screws fasten onto the disc drive, while the three larger screws secure the drive on the outside.
  10. Asus VivoBook X540SA-BPD0602V Disc Drive Disassembly: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the Phillips #00 screwdriver to remove the two screws (2.7 mm) on the side of the disc drive fastener.
  11. Asus VivoBook X540SA-BPD0602V Disc Drive Disassembly: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After removing the seven screws, lift the metal fastener from the disc drive with the plastic opening tool.
  12. Asus VivoBook X540SA-BPD0602V Disc Drive Disassembly: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the disc drive to the right, removing it from the laptop case.
Jessica Browne
crwdns2935283:010/18/17crwdne2935283:0
1,041 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S1-G111, Cagle Fall 2017 crwdns2935289:0USF Tampa, Team S1-G111, Cagle Fall 2017crwdne2935289:0
USFT-CAGLE-F17S1G111
I have a Asus X540U can I replace the ODD with a HDD SSD Caddy?
Rey Antipino Jr. - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,261
