The fan maintains the processor in its operating temperature. Dust buildup is common so it is essential to clean the fan occasionally. In extreme cases, the entire fan and heat sink assembly can be replaced.
Using the JIS #0 Screwdriver, unscrew the ten 10 mm screws that hold the back casing in place.
Pry open the back casing using the opening tool along the side crevice.
Remove the following screws that mount the fan and heatsink to the motherboard:
Three 3.0 mm screws for the fan
Four 2.0 mm screws for the heatsink
