This guide helps you replace the hard disk drive (HDD) in your Asus VivoBook Flip 14 TP410U.
Disconnect laptop from the power supply.
Use a Phillips #00 screwdriver to remove the ten 6.4 mm screws from the bottom cover.
Use a metal or nylon spudger to pry open the back cover on all sides.
Remove the back cover to access the inside where the hard disk drive is located.
Locate the hard-drive.
Disconnect the hard disk drive from its connectors, and remove the drive.
Hey, do you by any chance have the reference for the battery in the Asus TP410U ? Thank you!
