Asus UL80VT Motherboard Replacement
  1. Asus UL80VT Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the laptop so you can see the back side.
  2. Asus UL80VT Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus UL80VT Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Identify the two slide locks below the battery. Slide them outward towards the unlock symbol. You should see a red mark that indicates that the battery is unlocked and is ready for removal.
  3. Asus UL80VT Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now you can remove the battery while continuing to hold the right battery lock in the unlock position.
  4. Asus UL80VT Motherboard Replacement, Hard Drive: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus UL80VT Motherboard Replacement, Hard Drive: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus UL80VT Motherboard Replacement, Hard Drive: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the computer over, and unscrew the two 5 mm screws using the Phillips #0 screwdriver.
    • Lift the panel from the device.
  5. Asus UL80VT Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus UL80VT Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the hard drive away from the SATA connector and remove the hard drive from the device.
  6. Asus UL80VT Motherboard Replacement, RAM: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip computer over and unscrew the two 5 mm screws using the Phillips #0 screwdriver.
  7. Asus UL80VT Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus UL80VT Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus UL80VT Motherboard Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the clips toward the chassis of the computer. The RAM will pop up and can easily be removed.
  8. Asus UL80VT Motherboard Replacement, Keyboard: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus UL80VT Motherboard Replacement, Keyboard: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open laptop so the keyboard is accessible.
    • Insert a plastic prying tool and push and then pull to release the keyboard from the device.
  9. Asus UL80VT Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift keyboard and remove ZIF connector cables.
    • Remove the keyboard from the device.
  10. Asus UL80VT Motherboard Replacement, Motherboard: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the nine 5 mm screws using the Phillips #0 screwdriver.
  11. Asus UL80VT Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the laptop over and remove nine 5 mm screws using the Phillips #0 screwdriver.
  12. Asus UL80VT Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus UL80VT Motherboard Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the iFixit opening tool to remove the cd drive on the left of the laptop.
  13. Asus UL80VT Motherboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the same tool to remove the plastic top from the laptop.
  14. Asus UL80VT Motherboard Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the eight 3 mm screws using the Phillips #0 screwdriver.
    • Lift up the motherboard and disconnect all wires attaching the motherboard to the rest of the computer.
  15. Asus UL80VT Motherboard Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the motherboard out of the laptop and remove it from the device.
James DellaMorte
crwdns2935283:003/08/19crwdne2935283:0
660 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S1-G5, Botvin Spring 2019 crwdns2935289:0UMass Dartmouth, Team S1-G5, Botvin Spring 2019crwdne2935289:0
UMASSD-BOTVIN-S19S1G5
crwdns2942667:0crwdne2942667:0 599
