If you need to replace any keys or would like to customize them, you can access this guide. For this guide, you will need a plastic opening tool this guide.
Remove the outer layer that surrounds keys by using a metal spudger tool to pry it out.
Identify what keys are damaged or the ones you will be replacing. Using a plastic opening tool, gently pry the key up.
