We are going to teach you how to remove /replace the Lower Panel of your Asus U5OF-RBBAG05.
Turn the laptop over so the bottom is facing up.
Slide the two tabs on the bottom of the laptop toward the edges of laptop.
Slide the left tab to the left to lock it into the unlocked position. The red showing next to the tab signifies that it's unlocked.
Hold down the tab on the right side, then begin sliding the battery out.
Remove the old battery.
Remove the six screws using a Phillips #1 screwdriver.
Pry the lower panel up with your fingernail or a spudger.
