Asus U50F-RBBAG05 Motherboard Replacement
  1. Asus U50F-RBBAG05  Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the laptop over so the bottom is facing up.
    • Slide the two tabs on the bottom of the laptop toward the edges of laptop.
    • Slide the left tab to the left to lock it into the unlocked position. The red showing next to the tab signifies that it's unlocked.
    • You will have to hold the right tab to the right to keep the slot unlocked while removing the battery.
  2. Asus U50F-RBBAG05  Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus U50F-RBBAG05  Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Hold down the tab on the right side, then begin sliding the battery out.
    • Remove the old battery.
    • Next, insert the new battery into the empty slot. Release the right tab to begin locking the new battery into place. Slide the left tab to the right to completely lock the battery into the slot. The red that was showing near the left tab should be gone. This signifies that the battery is locked into place.
  3. Asus U50F-RBBAG05  Motherboard Replacement, Underpanel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the six screws using a Phillips #1 screwdriver.
  4. Asus U50F-RBBAG05  Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry the lower panel up with your fingernail or a spudger.
  5. Asus U50F-RBBAG05  Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus U50F-RBBAG05  Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up on the panel and remove it.
  6. Asus U50F-RBBAG05  Motherboard Replacement, Random Access Memory (RAM): crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus U50F-RBBAG05  Motherboard Replacement, Random Access Memory (RAM): crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push back on the silver clips shown in the picture until you hear/feel a pop.
  7. Asus U50F-RBBAG05  Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus U50F-RBBAG05  Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull back on the RAM card and remove it.
    • Repeat for the lower RAM card.
  8. Asus U50F-RBBAG05  Motherboard Replacement, Hard Drive: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two screws using a Phillips #1 screwdriver.
  9. Asus U50F-RBBAG05  Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus U50F-RBBAG05  Motherboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using your finger, push the hard drive back.
    • Pry up the drive with an opening tool (or your fingernail).
  10. Asus U50F-RBBAG05  Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus U50F-RBBAG05  Motherboard Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull back on the hard drive and lift upwards.
    • Remove the component completely.
  11. Asus U50F-RBBAG05  Motherboard Replacement, Fan and Heat Sink: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus U50F-RBBAG05  Motherboard Replacement, Fan and Heat Sink: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the Phillips #1 to remove two screws from the fan that attach it to the motherboard.
    • Remove the four screws on the heat sink.
  12. Asus U50F-RBBAG05  Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the bundled cable away from the connector in the same direction the individual wires are running.
    • Potential for device damage: Pull evenly on the connector so that no individual wires are overly strained.
  13. Asus U50F-RBBAG05  Motherboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus U50F-RBBAG05  Motherboard Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull up the heat sink a bit and then pull back.
    • There's an overhanging piece of the lower panel near the fan that you have to scoot out of.
    • Lift and remove both the fan and heat sink.
  14. Asus U50F-RBBAG05  Motherboard Replacement, Optical Drive: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single screw.
  15. Asus U50F-RBBAG05  Motherboard Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the plastic opening tool to push the drive out from the back.
  16. Asus U50F-RBBAG05  Motherboard Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus U50F-RBBAG05  Motherboard Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the drive out and remove completely.
    • When reassembling the drive, lay the laptop with the base towards the floor. Then, push the drive all the way in. Otherwise, the drive will become stuck and be difficult to reassemble.
  17. Asus U50F-RBBAG05  Motherboard Replacement, Keyboard: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus U50F-RBBAG05  Motherboard Replacement, Keyboard: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus U50F-RBBAG05  Motherboard Replacement, Keyboard: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert one of the pry tools under a top corner and the other tool under the side of the same corner. Make sure to get under the metal of the keyboard, not just the first layer of plastic. Then pry the corner down and out from under the little overhang its sitting under.
    • Next, slide the pry tool on the top over to the next overhang and insert the second tool on the other side. Push down and pry out the keyboard.
    • Repeat the same process all the way down to the opposite corner.
  18. Asus U50F-RBBAG05  Motherboard Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus U50F-RBBAG05  Motherboard Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the keyboard is free, lift it up slightly and release the cable connection underneath.
  19. Asus U50F-RBBAG05  Motherboard Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus U50F-RBBAG05  Motherboard Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Last, remove the keyboard completely from the computer.
  20. Asus U50F-RBBAG05  Motherboard Replacement, Upper Case: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus U50F-RBBAG05  Motherboard Replacement, Upper Case: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus U50F-RBBAG05  Motherboard Replacement, Upper Case: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the six screws from the outer lower case.
    • Remove the four screws from the hinges.
    • Remove the three screws on the inner lower case.
    • Remove the three screws from the optical drive area.
  21. Asus U50F-RBBAG05  Motherboard Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus U50F-RBBAG05  Motherboard Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two screws from the metal frame.
  22. Asus U50F-RBBAG05  Motherboard Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus U50F-RBBAG05  Motherboard Replacement: crwdns2935265:022crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus U50F-RBBAG05  Motherboard Replacement: crwdns2935265:022crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the two bundled cables away from the connector in the same direction as the individual wires are running.
    • Potential for device damage: Pull evenly on the full width of the cable so that no individual wires are overly strained.
    • Pull the no-fuss ribbon cable straight out of the connector.
    • Potential for device damage: These kinds of connectors are fairly rare, so check carefully for a way to release the connector before you resort to pulling on the ribbon cable.
    • Pull the single bundled cable away from the connector in the same direction as the individual wires are running.
  23. Asus U50F-RBBAG05  Motherboard Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up and remove the upper case.
  24. Asus U50F-RBBAG05  Motherboard Replacement, Motherboard: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus U50F-RBBAG05  Motherboard Replacement, Motherboard: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the six screws from the motherboard.
  25. Asus U50F-RBBAG05  Motherboard Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus U50F-RBBAG05  Motherboard Replacement: crwdns2935265:025crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus U50F-RBBAG05  Motherboard Replacement: crwdns2935265:025crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull three bundled cables away from their connectors in the same direction as the individual wires are running.
    • Potential for device damage: Pull evenly on the full width of each cable so that no individual wires are overly strained.
  26. Asus U50F-RBBAG05  Motherboard Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus U50F-RBBAG05  Motherboard Replacement: crwdns2935265:026crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus U50F-RBBAG05  Motherboard Replacement: crwdns2935265:026crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the laptop over.
    • Disconnect one wire.
    • Remove the tape connected to the white wire (which should not be connected to anything, but disconnect it if it is) and disconnect the black wire.
  27. Asus U50F-RBBAG05  Motherboard Replacement: crwdns2935265:027crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip laptop back over and remove the motherboard completely.
Kelly Greeling
crwdns2935283:002/07/17crwdne2935283:0
1.044 crwdns2915208:0crwdne2915208:0
University of Illinois Urbana-Champaign, Team 1-1, Scrogum Spring 2017 crwdns2935289:0University of Illinois Urbana-Champaign, Team 1-1, Scrogum Spring 2017crwdne2935289:0
UICU-SCROGUM-S17S1G1
crwdns2935297:019crwdne2935297:0
crwdns2942667:0crwdne2942667:0 718
