Asus Transformer Pad TF103C Speakers Replacement
  1. Asus Transformer Pad TF103C Speakers Replacement, Speakers: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Shut down your tablet before beginning the repair.
    • Insert the plastic opening tool on the side of the tablet.
    • Gently pull upwards and carefully pry open the tablet.
  2. Asus Transformer Pad TF103C Speakers Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the tool around all four sides of the tablet while gently pulling the tool up.
  3. Asus Transformer Pad TF103C Speakers Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back cover once you have loosened it from the tablet. Set the back cover aside.
    • Rotate the tablet to match the picture.
  4. Asus Transformer Pad TF103C Speakers Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully unplug the rainbow cable from the motherboard.
  5. Asus Transformer Pad TF103C Speakers Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the plastic opening tool to carefully pry the battery out from the frame.
  6. Asus Transformer Pad TF103C Speakers Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Transformer Pad TF103C Speakers Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the JIS #000 screwdriver to remove the four screws.
    • Keep the screws together and organized. (Label the screws, if necessary).
  7. Asus Transformer Pad TF103C Speakers Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take the ground wire out from the top of the TF103C-L (left) speaker.
    • If you pull on the wire too much it will break off.
    • If you break the wire off you can solder it back on.
  8. Asus Transformer Pad TF103C Speakers Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the tape and unplug the wire that is connected to both of the speakers.
  9. Asus Transformer Pad TF103C Speakers Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Transformer Pad TF103C Speakers Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two speakers from the frame.
Tyler Ellis
crwdns2935283:010/28/15crwdne2935283:0
668 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 3-6, Shastany Fall 2015 crwdns2935289:0UMass Dartmouth, Team 3-6, Shastany Fall 2015crwdne2935289:0
UMASSD-SHASTANY-F15S3G6
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 500
