Are you experiencing issues powering on your flip book? Is it losing it's charge very quickly? If so, this guide will help you replace a faulty battery in a few easy steps.
Remove the back 6mm and 8mm screws with a J000 screwdriver.
Remove the back cover of the flip book by gently using a metal spudger.
Unscrew the battery from the motherboard using a J000 screwdriver on the 3mm screws.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
The battery comes attached to the motherboard and needs to be disconnected before you can remove it.
Disconnect the battery from the motherboard by gently pulling out the connection with tweezers.
Gently remove the Wifi cables hooked to the rim of the battery
Remove the battery
how if my laptop not charge but the battery have replace before
its tooeasy! Thank You!
Its too easy! Tnks!
Where to find CMOS Battery?
