Asus Transformer Book T100TAF Battery Replacement
  1. Asus Transformer Book T100TAF Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Detach the keyboard from the screen by depressing the silver button the hinge and pulling upwards on the tablet.
  2. Asus Transformer Book T100TAF Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take the tablet-portion of the device and carefully pry the screen open using either the plastic or metal spudger. Each interior clip needs to be released from the edges.
  3. Asus Transformer Book T100TAF Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Transformer Book T100TAF Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the plastic backing from the device and locate the battery pack.
    • Battery pack
  4. Asus Transformer Book T100TAF Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Transformer Book T100TAF Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the plastic opening tool to pry the battery up from the device. Pry from different sides of the battery to loosen and break the glue that is holding it down.
    • The battery cable will release as the battery is removed from the device.
    • Be sure to recycle your old battery.
    • Do not puncture or bend the battery.
To reassemble your device, follow these instructions in reverse order. After replacement, it is advised to calibrate your new battery by fully draining the battery and then charging it, uninterrupted, to 100%.
Elizabeth
crwdns2935283:010/01/16crwdne2935283:0
589 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 4-3, Passmore Fall 2016 crwdns2935289:0USF Tampa, Team 4-3, Passmore Fall 2016crwdne2935289:0
USFT-PASSMORE-F16S4G3
Bonjour
Remplacement sans problème pour un ASUS T200TA
Par contre il a perdu le paramétrage du Boot.
Ou puis je retrouver ce parametrage??
jp.boubal - crwdns2934203:0crwdne2934203:0
Bonjour quelqu’un sait comment retirer la batterie d’origine de l’ordinateur (au niveau de la connection)?
Merci
Pierre-Alain Gallion - crwdns2934203:0crwdne2934203:0
Hi
What glue did you use to secure the new battery?
Thank you
Paul
Paul - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 83
crwdns2942667:0crwdne2942667:0 16,763
