Asus TF300T Tablet Display Replacement
crwdns2869540:0crwdne2869540:0: 1735
2
22
98
1,735
crwdns2955950:0crwdne2955950:0: 1
crwdns2960002:01crwdne2960002:0.
crwdns2959984:0crwdne2959984:0: 0
crwdns2959956:0crwdne2959956:0
crwdns2955944:0crwdne2955944:0: 15 - 25 crwdns2931279:0crwdne2931279:0
crwdns2955970:0crwdne2955970:0: crwdns2937803:0crwdne2937803:0
The display for the tablet is one of the hardest parts to replace as it is attached by glued and you will need a hair dryer. The broken screen affects the display's functionality and will need replacement.
    1. Asus TF300T Tablet Display Replacement, Display: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus TF300T Tablet Display Replacement, Display: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Disconnect the dock and make sure the power is turned off.
      • Use plastic opening tool to pry screen up and remove from outer casing.
      • Be gentle with the plastic opening tool when you reach the charging port as the thinner plastic could be broken easily.
    2. Asus TF300T Tablet Display Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus TF300T Tablet Display Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus TF300T Tablet Display Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Pull up on the black circuit board protector.
      • Turn off the hard power switch before working with the tablet. Use a tool to slide the switch to the position marked "off".
      • For most of the replacement operation, you do not have to remove the battery once you turned off the switch. Make sure that you do not short anything with the metal tools.
    3. Asus TF300T Tablet Display Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus TF300T Tablet Display Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus TF300T Tablet Display Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a Phillips #00 screwdriver to remove the 3mm screws connecting the battery to the motherboard.
      • Use the same screwdriver to remove two 3mm screws connecting the clips.
      • Use tweezers to remove two wires connected from the battery to the motherboard.
      • Use the spudger to remove the battery from the case.
    4. Asus TF300T Tablet Display Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus TF300T Tablet Display Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a Phillips #00 Screwdriver to remove the 3mm screws that connect the metal board with the screen.
      • Use a hairdryer on high and heat the edges of the screen. Melt the adhesive holding the screen to the casing of the tablet.
      • Take out the display away from the screen.
Khairuz Zaki Md Rujhan
crwdns2935283:005/22/17crwdne2935283:0
461 crwdns2915208:0crwdne2915208:0
IUPUI, Team S2-G2, Wilson Summer 2017 crwdns2935289:0IUPUI, Team S2-G2, Wilson Summer 2017crwdne2935289:0
IUPUI-WILSON-SU17S2G2
crwdns2935297:048crwdne2935297:0
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 98
crwdns2959996:0crwdne2959996:0 1,735
