Access and remove the left side USB Ports/Headphone Jack/ SD Card Slot.
Unscrew the 10 screws on the back cover
Remove back cover (pry open along the grey/black line, they are held together by clips)
Lift up tab and pull out the connector
Unscrew the 4 screws
Open up the screen (as you would to open up the laptop), and in doing so the metal piece will open up.
Jostle the ports and remove the small board.
crwdns2935229:05crwdne2935229:0
where can i buy the usb mic part?
I have a [newish] 14” Asus 3 [Blue Al./gold trim]. One of my grandchildren has wrecked one of the usb 3.1 sockets on the right [Output] side.
Is it possible to renew this socket? I have all the tools + mini soldering iron. I could connect the remaining one to a usb hub I suppose but it’s an expensive machine and I would rather it be repaired.
Any help/advice very much appreciated. Regards - Denis
