Asus ROG Zephyrus M15 GU502L Touchpad Replacement
  1. Asus ROG Zephyrus M15 GU502L Touchpad Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ROG Zephyrus M15 GU502L Touchpad Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove fifteen 10 mm screws from the bottom cover using a Phillips #0 screwdriver.
  2. Asus ROG Zephyrus M15 GU502L Touchpad Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ROG Zephyrus M15 GU502L Touchpad Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic opening tool to separate the back cover from the laptop.
    • It is recommended that you separate the laptop cover from the side and run the tool along the edge of the cover to open it.
    • Be careful not to damage the cover when removing it from the laptop.
  3. Asus ROG Zephyrus M15 GU502L Touchpad Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove six 4.8 mm screws that secure the battery using a Phillips #00 screwdriver.
  4. Asus ROG Zephyrus M15 GU502L Touchpad Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ROG Zephyrus M15 GU502L Touchpad Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the 8-pin battery that secures the battery to the motherboard.
    • Use the nylon tipped reverse tweezers to squeeze the edges, then pull out the connector.
  5. Asus ROG Zephyrus M15 GU502L Touchpad Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery from the computer.
  6. Asus ROG Zephyrus M15 GU502L Touchpad Replacement, Touchpad: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 3mm screws that secure the touchpad using a Phillips #0 screwdriver.
  7. Asus ROG Zephyrus M15 GU502L Touchpad Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the touch pad from the casing.
    • Be cautious picking up the touch pad as it is light.
Yahir Donis
crwdns2935283:009/07/23crwdne2935283:0
360 crwdns2915208:0crwdne2915208:0
Gateway, Team 69-69, Gonzalez Fall 2023 crwdns2935289:0Gateway, Team 69-69, Gonzalez Fall 2023crwdne2935289:0
GCC-GONZALEZ-F23S69G69
crwdns2942667:0crwdne2942667:0 544
