The ASUS laptop battery has been modified into a more compact form, making the battery not as accessible to easily replace. If your computer is not powering on even when connected to a power source. Here is a step-by-step guide of the ASUS ROG Zephyrus M15 GU502L battery replacement.
Remove fifteen 10 mm screws from the bottom cover using a Phillips #0 screwdriver.
Use a plastic opening tool to separate the back cover from the laptop.
Remove six 4.8 mm screws that secure the battery using a Phillips #00 screwdriver.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Disconnect the 8-pin battery that secures the battery to the motherboard.
Remove the battery from the computer.
