Start by unscrewing the bottom case. There are two different size screws. One long one short.
The ones marked in red are the short ones. As for the ones in orange are the long ones.
Using a plastic spudger push back the retaining clasp for the battery plug. It is a sliding motion so push it to the right with the battery closest to you.
Marked in red and orange are the screws that hold on the cooler. They are all the same size but I would still keep track of if it was holding on a fan or a block.
Marked in yellow are the power and signal wires for the fans. Using a plastic spudger slowly walk the male plug out of its socket.
Using the same spudger's flat side pry around the two dies. The old thermal paste will fight back so take your time.
Carefully remove the display cable concealed with plastic on the leftmost side of the board - marked in blue.
Remove the wifi coax cables (black and white) concealed with plastic to the rightmost side of the board - marked in pink.
Only then the cooling unit can be freely removed.
You can see where the thermal paste was so make sure to apply it on the same surfaces.
I have marked two small parts that are easy to miss.
I used 70% rubbing alcohol, tissues, and the flat end of a spudger to remove the old paste.
I used a plastic spudger to spread the paste on the chips to make sure that it will make full contact.
Replace the cooler by reversing the steps in step 3.
Button up the device by placing and screwing on the bottom case.
The screws marked in orange are long. The ones marked in red are short.
I had a problem getting the two long ones that seem to be close to the battery. On my laptop the screw size was a bit smaller and rather tight and so they peeled. I’ve tried the rubber band trick to no avail. Don’t want to force it and break it. Is there any safe way to get these screws out?
Go up one or two sizes of screwdriver bits. From there go slow and use a good amount of pressure (Almost more than you think you will need) pushing strait down on top of the screw.
I would leave those screws out from reassembly. It wont hurt anything to be missing a screw or two. -
After new Thermal paste.
For the testing, I used 3D mark time spy without the demo. As well as a custom fan curve. The profile was set to turbo for both runs.
crwdns2935229:015crwdne2935229:0
crwdns2947412:010crwdne2947412:0
I used metal tweezers and my laptop won’t turn on now. What did I do?
Did you manage to get an answer to this? I didn't use metal tweezers but my laptop won't turn on and it's blinking as if it's trying to run but it can't!
Open up chips and look if there are cracks on chips, if there are, then you got a dead chip.
You have probably created a spark between the tweezers and the laptop circuit while the battery power is still on, bring it to a repair shop that provides micro soldering service and let them fix it.
Jerry Li -
I followed this and even used ifixit tools and now my laptop won't boot. No bios, no charge light, no cpu light, no fans. I followed it exactly, grounded myself, didn't touch the motherboard, didn't even get up as to not accidentally generate static, worked on concrete and a wooden table, none of the connections are loose or damaged. It just won't turn on. What happened and how can I fix it?
I’d go in and check for any connections on the motherboard that you may have missed and also look out for any broken ones. Try reseating any connections such as the battery connector and display cable.
For anybody using this method leave it for a professional or risk frying your motherboard. It's a death trap. Once the metal plug gets in contact with your mother board it fries everything. I need re pasting but haven't tried this method. I'm scared to.
Sunfin -
I recently did this. Some things I would amend however.
In step 2, when the battery is unplugged push the power button 3-5 times and hold it down for 5-10 seconds, just in case the capacitors are still holding charge. This might be what happened to the user who had his device short.
I left the coaxial cables attached, in step 3, and just removed the screw holding in the Wi-Fi card, moving the whole assembly aside.
Also in step 5, I had issues with the power connector. I had to redo the connection several times before the device turned on.
It's not mentioned anywhere, but you should definitely have a small brush ready to clean the fans. If you are scared of doing the re-paste, cleaning the fans out may do enough to get you by.
Lastly, I used 3.5g of Noctua NT-H2. I was nervous that 1g of paste wouldn't be enough, and I think that was a good assumption. I've seen several posts/videos that suggest using K5 Pro on the VRM's, it doesn't appear that's needed, but we shall find out.
I followed this guide, and now my laptop is running 20C cooler! I also had an issue where it wouldn't power on after plugging the battery back in. However, I unplugged the battery, plugged in the power supply and it powered up. After that I plugged the battery back in and working perfect. Good guide, and highly appreciated.
"Regular" thermal paste is not to be used on VRAM and VRMs. The blue stuff applied by the OEM is a Viscous thermal compound, which has a thicker consistency because it's filling a wider gap. It is an alternative to thermal pads.
Your typical thermal grease will underperform and makes a huge mess to clean up.
For those areas, you're after K5 Pro, Laird TPutty, or Parker Therm-A-Gap.
