Asus ROG Strix GL702VS Trackpad Replacement
  1. Asus ROG Strix GL702VS Trackpad Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the computer so the bottom of the laptop is facing up.
  2. Asus ROG Strix GL702VS Trackpad Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the ten JIS #0 screws around the edge of the laptop.
    • The two bottom screws are slightly shorter
  3. Asus ROG Strix GL702VS Trackpad Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ROG Strix GL702VS Trackpad Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Jimmy to carefully free each side of the bottom casing.
  4. Asus ROG Strix GL702VS Trackpad Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up the back casing from the computer.
    • You may hear clicking or snapping sounds. This is just the plastic clips coming loose.
  5. Asus ROG Strix GL702VS Trackpad Replacement, Trackpad: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus ROG Strix GL702VS Trackpad Replacement, Trackpad: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus ROG Strix GL702VS Trackpad Replacement, Trackpad: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the ribbon cables from the connectors at the bottom of the motherboard by lifting up the tabs with a nylon spudger tool.
    • Slide the ribbon cables out of the connectors on the motherboard.
  6. Asus ROG Strix GL702VS Trackpad Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ROG Strix GL702VS Trackpad Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the covering foil holding the trackpad into place.
    • Completely peel the foil back to ensure it does not interfere with the following processes.
  7. Asus ROG Strix GL702VS Trackpad Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ROG Strix GL702VS Trackpad Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up speaker cable that is laying overtop using a pair of tweezers.
    • Do not to overextend the wire since you may accidently pull the wire out.
  8. Asus ROG Strix GL702VS Trackpad Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus ROG Strix GL702VS Trackpad Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus ROG Strix GL702VS Trackpad Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the three 4mm JIS #0 screws that are securing the trackpad.
  9. Asus ROG Strix GL702VS Trackpad Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ROG Strix GL702VS Trackpad Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once freed, slide the trackpad backwards towards the center of laptop.
    • This may require some jiggling. Lifting the laptop off your working surface may help.
    • Sliding the trackpad back in can be a bit tricky. Ensure it is fully seated before continuing reassembly.
Conor H Allen
crwdns2935283:009/16/19crwdne2935283:0
622 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S8-G6, Salas Fall 2019 crwdns2935289:0Embry-Riddle Aeronautical University, Team S8-G6, Salas Fall 2019crwdne2935289:0
ERAU-SALAS-F19S8G6
crwdns2942667:0crwdne2942667:0 1,006
