This simple guide will be used in almost every step involved in repairing the computer. You will need to remove the bottom cover to access all of the components of the computer. This should be done in a contained well-lit setting since the small screws may be easy to lose in low light settings.
Flip the computer so the bottom of the laptop is facing up.
Remove the ten JIS #0 screws around the edge of the laptop.
The two bottom screws are slightly shorter
Use a Jimmy to carefully free each side of the bottom casing.
Lift up the back casing from the computer.
