Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement
  1. Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement, Back Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the laptop over to the back panel, with the serial numbers facing up.
    • Using a Phillips #1 screwdriver, remove the ten 12 mm screws from the back panel.
  2. Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The snap seals don't need a lot of pressure to open, and may break if forced. Be gentle with the opening tool.
    • Wedge the sharp edge of the plastic opening tool into the seam between the back panel and the rest of the laptop, then gently pry the panel up.
    • There will be a snapping sound as you remove the back panel, but that is just the seal loosening.
    • Continue breaking the seals by sliding the plastic opening tool around the entire laptop under the seam until the back panel is free.
    • Once you have broken all the seals, carefully lift the panel off.
  3. Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the battery from the motherboard.
  4. Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the 3.8 mm Phillips #1 screw on the top right hand corner of the battery.
    • Lift battery from laptop frame.
  5. Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement, Wifi Card: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement, Wifi Card: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement, Wifi Card: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the iFixit Opening Tool, disconnect the black and white coaxial cables from the wifi card.
    • Using a Phillips #1 screwdriver, remove the 4mm retaining screw.
    • Gently slide the wifi card out from the connection slot.
Alexander Van Auker
crwdns2935283:009/16/20crwdne2935283:0
79 crwdns2915208:0crwdne2915208:0
The Citadel Military College of South Carolina, Team S1-G3, Eggleston Fall 2020 crwdns2935289:0The Citadel Military College of South Carolina, Team S1-G3, Eggleston Fall 2020crwdne2935289:0
CMCSC-EGGLESTON-F20S1G3
crwdns2936753:030crwdne2936753:0 35
crwdns2942667:0crwdne2942667:0 2,973
