Asus ROG Strix GL553VD Battery Replacement
  1. Asus ROG Strix GL553VD Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ROG Strix GL553VD Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a JIS screwdriver to remove the ten 4 mm screws from the bottom cover.
    can i know the screw type of backpanel , the screws near the backpanel side of battery placement
    Reflection - crwdns2934203:0crwdne2934203:0
  2. Asus ROG Strix GL553VD Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ROG Strix GL553VD Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the flap in the middle to reveal the 11th screw and remove it using the same JIS screwdriver.
  3. Asus ROG Strix GL553VD Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus ROG Strix GL553VD Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus ROG Strix GL553VD Battery Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently lift each corner to remove the cover from the laptop.
    • If you seem to have difficulty removing the cover, you may use a plastic opening tool to pry up one of the corners to get you started.
  4. Asus ROG Strix GL553VD Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus ROG Strix GL553VD Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus ROG Strix GL553VD Battery Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently pull the white battery connector out towards the battery.
  5. Asus ROG Strix GL553VD Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift the battery out from the case to remove it.
    • The battery will come off easily as the screws are already removed.
Mahmoud Mehdi
crwdns2935283:009/20/20crwdne2935283:0
247 crwdns2915208:0crwdne2915208:0
York University, Team S1-G89, Woodhouse Fall 2020 crwdns2935289:0York University, Team S1-G89, Woodhouse Fall 2020crwdne2935289:0
YORK-WOODHOUSE-F20S1G89
Thank you for the guide. It was tricky to find the screw in the middle, hidden behind the flap. The screws are however not torx as shown.
Soheil Roshanbin - crwdns2934203:0crwdne2934203:0
Hi,
Great job... quick and easy !
I've changed the battery of my ASUS ROG GL553VD but there is a problem... the battery doesn't charge and it is noticed a charge level at 255% in windows o_O Do you know if another action is needed ?
Aurélien F - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 54
crwdns2942667:0crwdne2942667:0 5,245
