This is a simple guide on how to replace the battery in your Asus ROG Strix GL553VD gaming laptop.
Lithium batteries such as the one inside your gaming laptop deteriorate over time, losing their ability to hold a charge. This may not be a problem if you use your gaming laptop plugged in most of the time, but if you travel with your laptop and notice the laptop holding less charge and lasting for less time while on battery power, a battery replacement may restore some of the functionality of your laptop.
Happy fixing!
Use a JIS screwdriver to remove the ten 4 mm screws from the bottom cover.
Open the flap in the middle to reveal the 11th screw and remove it using the same JIS screwdriver.
Gently lift each corner to remove the cover from the laptop.
Gently pull the white battery connector out towards the battery.
Carefully lift the battery out from the case to remove it.
Thank you for the guide. It was tricky to find the screw in the middle, hidden behind the flap. The screws are however not torx as shown.
can i know the screw type of backpanel , the screws near the backpanel side of battery placement
Reflection - crwdns2934203:0crwdne2934203:0
