Asus ROG STRIX GL502V Motherboard Replacement
  1. Asus ROG STRIX GL502V Motherboard Replacement, Asus ROG STRIX GL502V Lower Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ROG STRIX GL502V Motherboard Replacement, Asus ROG STRIX GL502V Lower Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove 10 screws.
    • Note: front screws (blue) are 10mm long, central and rear (brown) are 12mm.
  2. Asus ROG STRIX GL502V Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ROG STRIX GL502V Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With opening tool or pick go around the case starting from back corner.
  3. Asus ROG STRIX GL502V Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift cover and now you have access to most of the components.
  4. Asus ROG STRIX GL502V Motherboard Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect battery connect by pulling it up.
  5. Asus ROG STRIX GL502V Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove 4 screws
  6. Asus ROG STRIX GL502V Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift battery up and out.
  7. Asus ROG STRIX GL502V Motherboard Replacement, Remove memory module: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull spring locks out.
    • Lift module up and out of the connector.
  8. Asus ROG STRIX GL502V Motherboard Replacement, M.2 SSD: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • remove screw.
    • pull up and right from the connector.
  9. Asus ROG STRIX GL502V Motherboard Replacement, Connectors: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Antenna (orange)
    • Speakers (yellow)
    • Power and miscellaneous LED (blue)
    • Keyboard (green)
    • Display (pink)
  10. Asus ROG STRIX GL502V Motherboard Replacement, Remove speaker connector: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ROG STRIX GL502V Motherboard Replacement, Remove speaker connector: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove speaker connector by pulling it out.
  11. Asus ROG STRIX GL502V Motherboard Replacement, Remove keyboard connector: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus ROG STRIX GL502V Motherboard Replacement, Remove keyboard connector: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus ROG STRIX GL502V Motherboard Replacement, Remove keyboard connector: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift locking mechanism up
    • Pull ribbon cable from connector
  12. Asus ROG STRIX GL502V Motherboard Replacement, Remove miscellanious connectors: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ROG STRIX GL502V Motherboard Replacement, Remove miscellanious connectors: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift locking tab on each connector (3x)
    • Pull each ribbon cable out
  13. Asus ROG STRIX GL502V Motherboard Replacement, Display cable: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus ROG STRIX GL502V Motherboard Replacement, Display cable: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus ROG STRIX GL502V Motherboard Replacement, Display cable: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove screw holding display cable
    • Remove plastic shield over display cable
    • Pull cable out of the clip
  14. Asus ROG STRIX GL502V Motherboard Replacement, Display connector: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ROG STRIX GL502V Motherboard Replacement, Display connector: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull display connector straight up by the pull strap
  15. Asus ROG STRIX GL502V Motherboard Replacement, Antenna connector: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus ROG STRIX GL502V Motherboard Replacement, Antenna connector: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus ROG STRIX GL502V Motherboard Replacement, Antenna connector: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully holding by metal part pull connector up.
    • Repeat for second connector.
  16. Asus ROG STRIX GL502V Motherboard Replacement, Antenna connector cable: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ROG STRIX GL502V Motherboard Replacement, Antenna connector cable: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Move connector out of the guide.
  17. Asus ROG STRIX GL502V Motherboard Replacement, Hinges screws: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ROG STRIX GL502V Motherboard Replacement, Hinges screws: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove remaining hinges screws (5)
    • Note: one screw was holding display cable.
  18. Asus ROG STRIX GL502V Motherboard Replacement, Lift Hinghes: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ROG STRIX GL502V Motherboard Replacement, Lift Hinghes: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift left hinge up.
    • Lift right hinge up.
  19. Asus ROG STRIX GL502V Motherboard Replacement, Motherboard screws: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove two side motherboard screws (yellow marks)
    • Remove 4 center screws (green marks)
    • Note: side screws silver and slighter longer.
  20. Asus ROG STRIX GL502V Motherboard Replacement, Remove motherboard: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus ROG STRIX GL502V Motherboard Replacement, Remove motherboard: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus ROG STRIX GL502V Motherboard Replacement, Remove motherboard: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • NOTE: Headset connector is holding in the case.
    • Lift motherboard from HDMI connector side and pull towards it.
  21. Asus ROG STRIX GL502V Motherboard Replacement, Remove fans, heat sink and radio module: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove radio module screw (red) and pull it out of connector.
    • Disconnect fans connectors and remove 6x screws. Pull fans out.
    • Remove 8 screws from heat sink and remove it.
    • Note: heat sink use thermal paste on CPU and GPU - you will need to clean and use new before putting it together.
Sergei
crwdns2935283:009/10/12crwdne2935283:0
650 crwdns2915208:0crwdne2915208:0
Hello I am interested motherboard, how much it's the price ?
Leonard Cristian - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 85
crwdns2942667:0crwdne2942667:0 1,420
