Asus ROG GL551J Screen Replacement
  1. Asus ROG GL551J Screen Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lay the device on a flat surface with the battery facing up.
    • Be sure to wear ESD or Rubber gloves to protect the computer components.
    could provide a link on where to purchase screens or a link for this specific model, they are hard to find
    Anika Rozeboom - crwdns2934203:0crwdne2934203:0
  2. Asus ROG GL551J Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push the latch found below the battery to the unlock position.
  3. Asus ROG GL551J Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the battery out.
  4. Asus ROG GL551J Screen Replacement, Screen: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ROG GL551J Screen Replacement, Screen: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic opening tool to remove the plastic hinge covers on either side of the laptop.
  5. Asus ROG GL551J Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ROG GL551J Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the middle screws located on either side of the display.
    could specify the middle screw
  6. Asus ROG GL551J Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ROG GL551J Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic opening tool to pop out the bezel from all four sides, then lift it out of the frame.
    • When doing this in reverse during reassembly, try closing the laptop and applying pressure to reattach the bezel snaps.
  7. Asus ROG GL551J Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws at each corner of the display.
  8. Asus ROG GL551J Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ROG GL551J Screen Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the connector from the display by pulling the wire downwards.
    • Be sure to take note of the orientation of the connector when unplugging and plugging in.
    indicate that direction of the wire is important and should be noted
    instead of saying to do this in reverse order, we should recommend that when you have your new screen to reconnect the battery, connect the cable to the screen and make sure it works. ALSO rubber gloves could be very helpful with this type of procedure
Thien Vu
crwdns2935283:002/15/17crwdne2935283:0
412 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 5-4, Lacy Spring 2017 crwdns2935289:0USF Tampa, Team 5-4, Lacy Spring 2017crwdne2935289:0
USFT-LACY-S17S5G4
Hey, I am having issues putting the plastic hinge caps back on after I'm done. I know there is a right one and a left one but I just don't know how to pop them back into place. Starting to get a bit desperate. Could anyone give me some tips?
Thanks!
Teodor Andonov - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 3,254
