An optical drive replacement guide for the Asus ROG GL551J.
Lay the device on a flat surface with the battery facing up.
Push the latch found below the battery to the unlock position.
Pull the battery out.
Locate and unscrew the screw which connects the optical drive to the chassis
Pull on the optical drive gently. With little resistance, the optical drive should just slide out
ok.so , if someone had replaced the dvd rom with a hard disk drive i nust do the same for replace the drive?
could provide a link on where to purchase screens or a link for this specific model, they are hard to find
Anika Rozeboom - crwdns2934203:0crwdne2934203:0
