Asus ROG GL551J Hard Drive Replacement
  1. Asus ROG GL551J Hard Drive Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lay the device on a flat surface with the battery facing up.
    • Be sure to wear ESD or Rubber gloves to protect the computer components.
  2. Asus ROG GL551J Hard Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push the latch found below the battery to the unlock position.
  3. Asus ROG GL551J Hard Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the battery out.
  4. Asus ROG GL551J Hard Drive Replacement, Hard Drive: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ROG GL551J Hard Drive Replacement, Hard Drive: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With laptop upside-down, locate and unscrew the two screws on the panel with the vents.
    • Slide the panel out and lift up to remove.
  5. Asus ROG GL551J Hard Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ROG GL551J Hard Drive Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The hard drive is the metal rectangle with the two soft padding bars attached to it.
    • Locate and remove the 4 screws holding the hard drive down at each corner using a PH000 Philips head.
  6. Asus ROG GL551J Hard Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ROG GL551J Hard Drive Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the black plastic tab attached to the bottom of the hard drive and pull it straight outwards.
    • Failure to correctly disconnect the hard drive before pulling it up and out can damage the connectors.
    • Once the hard drive detaches from the connector, lift the hard drive up and out.
Thien Vu
crwdns2935283:002/15/17crwdne2935283:0
412 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 5-4, Lacy Spring 2017 crwdns2935289:0USF Tampa, Team 5-4, Lacy Spring 2017crwdne2935289:0
USFT-LACY-S17S5G4
crwdns2942667:0crwdne2942667:0 4,836
