Use this guide to remove replace the hard drive in your Asus ROG GL551J, which can be completed in fewer than 3 steps.
Lay the device on a flat surface with the battery facing up.
Push the latch found below the battery to the unlock position.
With laptop upside-down, locate and unscrew the two screws on the panel with the vents.
Slide the panel out and lift up to remove.
The hard drive is the metal rectangle with the two soft padding bars attached to it.
Locate and remove the 4 screws holding the hard drive down at each corner using a PH000 Philips head.
Locate the black plastic tab attached to the bottom of the hard drive and pull it straight outwards.
Once the hard drive detaches from the connector, lift the hard drive up and out.
