Use this guide to replace the CD drive in your device.
Lift up the rubber tab located in the upper-right corner of the backing plate.
Use a Phillips #1 screwdriver to remove the 5.2 mm screw behind the rubber tap.
Carefully pull the backing plate off. If you have a pry tool, you can pry on the edges carefully.
Use a Phillips #1 screwdriver to remove the 5 mm screw.
Pull out the drive and remove it from the device.
