Asus ROG G750JS keyboard (palmrest) Replacement
  1. Asus ROG G750JS keyboard (palmrest) Replacement, pull out battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the laptop
    • Unlock and pull out the battery
  2. Asus ROG G750JS keyboard (palmrest) Replacement, unscrew back panel access: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus ROG G750JS keyboard (palmrest) Replacement, unscrew back panel access: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus ROG G750JS keyboard (palmrest) Replacement, unscrew back panel access: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate and unscrew the screw under the rubber cover
    • pop out the plastic cover
    • unscrew 5 screws marked in the picture (keep the screws separated by length and color)
  3. Asus ROG G750JS keyboard (palmrest) Replacement, unscrew the outer screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • pop out the rubbers plugs (7) around the laptop
    • unscrew screws under the plugs
  4. Asus ROG G750JS keyboard (palmrest) Replacement, remove screws under battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • remove 5 screws from the battery panel
  5. Asus ROG G750JS keyboard (palmrest) Replacement, remove optical drive: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If you have removed screw C in step 3 (pointed at in the picture) you can pull out the optical drive
    • remove all 3 screws revealed by removing the drive
  6. Asus ROG G750JS keyboard (palmrest) Replacement, remove speakers: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus ROG G750JS keyboard (palmrest) Replacement, remove speakers: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus ROG G750JS keyboard (palmrest) Replacement, remove speakers: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • flip laptop
    • pop open the speaker part
    • unplug speakers
    • remove 1 black screw on both sides
  7. Asus ROG G750JS keyboard (palmrest) Replacement, pop out the front plate: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • using a plastic prying tool separate the front plate(keyboard) from the rest of the laptop
  8. Asus ROG G750JS keyboard (palmrest) Replacement, detach the keyboard: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ROG G750JS keyboard (palmrest) Replacement, detach the keyboard: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • gently lift the front plate
    • detach all four ribbons connecting the front plate to the motherboard
    • keep the light colored ribbon (it can be detached from the front plate as well)
  9. Asus ROG G750JS keyboard (palmrest) Replacement, connect and push in the new part: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ROG G750JS keyboard (palmrest) Replacement, connect and push in the new part: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • connect the new front plate in the same spots as the old one
    • if needed reconnect the light colored ribbon on both the front plate and the motherboard
    • push the new plate back in place, make sure all sides are in
  10. Asus ROG G750JS keyboard (palmrest) Replacement, put back the black screws: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ROG G750JS keyboard (palmrest) Replacement, put back the black screws: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • put back the black screws holding the front plate
  11. Asus ROG G750JS keyboard (palmrest) Replacement, reconnect and close the speaker panel: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ROG G750JS keyboard (palmrest) Replacement, reconnect and close the speaker panel: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • reconnect the speakers
    • push in place the whole speaker panel
  12. Asus ROG G750JS keyboard (palmrest) Replacement, put back the optical drive: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ROG G750JS keyboard (palmrest) Replacement, put back the optical drive: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • screw back the 3 screws in the optical drive slot
    • slide in the drive
    • secure with screw C (circled in second picture)
  13. Asus ROG G750JS keyboard (palmrest) Replacement, return back panel: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus ROG G750JS keyboard (palmrest) Replacement, return back panel: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus ROG G750JS keyboard (palmrest) Replacement, return back panel: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • put in place all screws in the back panel
    • the screw on the very left is the longest
    • push back in the plastic cover
    • return the silver screw covered by the rubber cover
  14. Asus ROG G750JS keyboard (palmrest) Replacement, put back in the battery: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ROG G750JS keyboard (palmrest) Replacement, put back in the battery: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • screw in the last 5 screws in the battery panel
    • push back in the battery
    • done!
hornikmartinrepair
crwdns2935283:007/06/16crwdne2935283:0
357 crwdns2915208:0crwdne2915208:0
@Anthony+Massmann I don’t remember exactly. It’s most likely for the touch pad considering it’s location.
hornikmartinrepair - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,045
