This guide covers how to replace the RAM for the Asus ROG G750JH-DB71.
The RAM provides memory for the Asus ROG G750JH-DB71 while running the operating system. This allows the Asus ROG G750JH-DB71 to do many tasks from taxing videogames and programs to browsing the internet. Damage to Asus ROG G750JH-DB71's RAM could cause random crashing or a slow operating system.
To test if it's your RAM is causing these problems you can test this using free diagnostic programs on the internet.
The Asus ROG G750JH-DB71 comes with a 12 GB DDR3-SDRAM and 24 GB of RAM in total. You can add up to 32 GB of RAM (32000 MB)
Flip the laptop over so the bottom case is facing up.
Push the switch near the front of the laptop to release the battery from the computer.
Pull the battery out and away from the center of the computer.
Use a spudger or your finger to lift up the plastic cover on the bottom of the laptop.
Under the plastic cover is a captive screw; unscrew it using a Phillips #00 screwdriver.
Remove the hard drive by unscrewing the 4.4 mm Phillips #00 screws.
Remove all of the plastic caps around the edges using a spudger. Remove the screws underneath the caps.
Remove the remaining screws underneath the cover.
You will find a metal tab holding the disc drive in place. Push on the tab with a spudger to remove the disc drive. It is located below a previously removed screw.
Remove the three 4 mm Phillips #00 screws that were previously covered by the disc drive.
The back cover can be taken off by hand.
Disconnect the speaker cables.
Remove two 8 mm Phillips #00 screws on each corner.
Pry the keyboard gently using a spudger.
Now you can pull the keyboard off but make sure to do so carefully without damaging or scuffing any components.
Pull up and out at an angle to avoid damaging the internals of the laptop.
The RAM module is located directly in the center of the computer on top of the motherboard.
Push in the two levers on each side of the RAM module. This frees the module from the slot and allows removal.
Once loose, pull the RAM module away from the slot at a 45 degree angle as to not damage it.
