Asus ROG FX60VM Hard Drive Replacement
  1. Asus ROG FX60VM Hard Drive Replacement, HDD: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ROG FX60VM Hard Drive Replacement, HDD: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before disassembling the laptop, turn the laptop off and make sure it's unplugged from the power supply.
  2. Asus ROG FX60VM Hard Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus ROG FX60VM Hard Drive Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus ROG FX60VM Hard Drive Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the laptop over so the back case is facing up.
    • Remove the ten 2.5 mm screws from the back case using a Phillips #0 screwdriver.
    • Use a plastic opening tool and picks to pry the back panel off of the device.
  3. Asus ROG FX60VM Hard Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus ROG FX60VM Hard Drive Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus ROG FX60VM Hard Drive Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Halberd Spudger
    $2.99
    • Put the tip of Halberd spudger under the battery connector and lift it gently to disconnect it from the motherboard.
    • You may need to wiggle the spudger up and down in order to disconnect the battery connector.
  4. Asus ROG FX60VM Hard Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ROG FX60VM Hard Drive Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 3.0 mm screws from the HDD case using a Phillips #1 screwdriver.
  5. Asus ROG FX60VM Hard Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus ROG FX60VM Hard Drive Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus ROG FX60VM Hard Drive Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Do not lift the HDD up, as you may damage the connector highlighted in red.
    • Hold the back of the HDD , and slide it out of the port to disconnect it from the motherboard.
  6. Asus ROG FX60VM Hard Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus ROG FX60VM Hard Drive Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus ROG FX60VM Hard Drive Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 3.0 mm screws on each side of the HDD mounting bracket using a Phillips #1 screwdriver.
    • Lift the HDD out of the mounting bracket, and install a new HDD or SSD to the mounting bracket.
After install a new HDD or SSD, for better performace, initialize the new disk.
JingZhao Liang
crwdns2935283:006/26/22crwdne2935283:0
163 crwdns2915208:0crwdne2915208:0
York University, Team M-13, Allen Summer 2022 crwdns2935289:0York University, Team M-13, Allen Summer 2022crwdne2935289:0
YORK-ALLEN-SU22SMG13
Thank you so much JingZhao Liang for the concise and to the point guide. It's easy to follow and I am very impressed that you mentioned how to dispose the e-waste properly in conclusion part.
Tayyaba Riasat - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 806
