Asus R510CA-OB01 Keyboard and Mousepad Replacement
  1. Asus R510CA-OB01 Keyboard and Mousepad Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus R510CA-OB01 Keyboard and Mousepad Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus R510CA-OB01 Keyboard and Mousepad Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the two switches that lock the battery.
    • Then, push the right switch outward to unlock it.
  2. Asus R510CA-OB01 Keyboard and Mousepad Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus R510CA-OB01 Keyboard and Mousepad Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push the left switch outward and push the battery upward at the same time.
  3. Asus R510CA-OB01 Keyboard and Mousepad Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Li-ion battery as a replacement for your battery.
  4. Asus R510CA-OB01 Keyboard and Mousepad Replacement, Keyboard and Mousepad: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Shut down the computer and disconnect all external devices connected to it.
    • Turn the computers that it is upside down. Position the computer with the front towards you.
  5. Asus R510CA-OB01 Keyboard and Mousepad Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After detaching the battery, remove the two 5mm screws holding down the casing using a Phillips #00 screwdriver.
  6. Asus R510CA-OB01 Keyboard and Mousepad Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus R510CA-OB01 Keyboard and Mousepad Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Loosen the four 12mm screws on the bottom and top panel of your device using a Phillips #0 screwdriver.
  7. Asus R510CA-OB01 Keyboard and Mousepad Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus R510CA-OB01 Keyboard and Mousepad Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus R510CA-OB01 Keyboard and Mousepad Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the grips to slide the panel off.
    • Remove the panel by lifting it off the device.
  8. Asus R510CA-OB01 Keyboard and Mousepad Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus R510CA-OB01 Keyboard and Mousepad Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three 5mm screws holding down the hard drive and the five 5mm screws holding down the casing using a Phillips #00 bit.
  9. Asus R510CA-OB01 Keyboard and Mousepad Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus R510CA-OB01 Keyboard and Mousepad Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the laptop the right way up and face it towards you.
    • Insert the flat edge of the flat plastic opening tool into the crease of the keyboard cover.
    • While the opening tool is in the crease, carefully pry open the casing by sliding the plastic opening tool along the edge.
  10. Asus R510CA-OB01 Keyboard and Mousepad Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus R510CA-OB01 Keyboard and Mousepad Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Make sure that the entire cover has been released front the plastic pins.
    • Slowly lift the cover open from the front of the laptop but do not completely remove.
    • Note the three locations of the three white and blue data cables connecting the keyboard to the computer's main board.
  11. Asus R510CA-OB01 Keyboard and Mousepad Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus R510CA-OB01 Keyboard and Mousepad Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus R510CA-OB01 Keyboard and Mousepad Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove each data cable from the motherboard by using your finger or the plastic opening tool to lift the white latch.
    • The cable will slide out of its place.
  12. Asus R510CA-OB01 Keyboard and Mousepad Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus R510CA-OB01 Keyboard and Mousepad Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the data cables removed and the keyboard module fully disconnected, the keyboard module should come free from the laptop.
Blanche Pinto
crwdns2935283:009/28/17crwdne2935283:0
437 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S3-G4, Nance Fall 2017 crwdns2935289:0USF Tampa, Team S3-G4, Nance Fall 2017crwdne2935289:0
USFT-NANCE-F17S3G4
crwdns2942667:0crwdne2942667:0 916
