Replacing the battery is helpful when the battery will not hold a charge for an extended period of time. Make sure the computer is unplugged and turned off the entire time. For any other problems follow the device troubleshooting page here.
Remove all ten screws on the back of the laptop to remove the cover.
Remove the cover.
Disconnect the wires at the top of the battery by lifting on the tabs protruding out of the plastic frame.
Remove the four screws holding the battery in place, two on top and one on each side.
Gently lift out the battery by the side closest to the motherboard first.
Greetings I have tried to pull the battery out but i have issues making it go out of the place where it clicks, could you make a detailed video on how to safely remove that part without breaking the wires or the soldering on the board???
