This guide is intended to show how to remove a damaged screen from the laptop. Reversing the steps will describe the steps needed to replace the laptop with a new screen.
Unscrew the 10 screws around the edge of the back panel. Eight of the screws are 0.0793mm T5 , two of them are 0.0793 JIS #0.
Use the plastic opening tool to pry the back panel off the base of the laptop.
Unscrew the four screws to remove the battery.
Un-clip both wire clips on the upper and right side of the battery.
Lift the battery out of the device.
Use the metal spudger to gently lift the two plastic squares off the screen.
Unscrew the two PH0 screws and set them aside.
Use the plastic opening tool to pry the front edges of the screen off of the back.
Take off the tapes.
Gently pry the LCD from the front frame.
