These steps will show you how to remove the hard drive from you computer.
You will need to do that if the hard drive is in a good condition but the computer is not, replace it to a new one to increase the speed and capacity, or the hard drive has experienced a hardware failure.
Unscrew the 10 screws around the edge of the back panel. Eight of the screws are 0.0793mm T5 , two of them are 0.0793 JIS #0.
Use the plastic opening tool to pry the back panel off the base of the laptop.
Unscrew the four 0.0793 mm screws.
Using the PH0 and screwdriver from the 54 Bit Driver kit.
After removing the four screws, gently push the hard drive downward as shown.
