Asus Q551L Battery Replacement
  1. Asus Q551L Battery Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Q551L Battery Replacement, Back Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the 10 screws around the edge of the back panel. Eight of the screws are 0.0793mm T5 , two of them are 0.0793 JIS #0.
  2. Asus Q551L Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the plastic opening tool to pry the back panel off the base of the laptop.
  3. Asus Q551L Battery Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Q551L Battery Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the four screws to remove the battery.
  4. Asus Q551L Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Q551L Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Un-clip both wire clips on the upper and right side of the battery.
    • Lift the battery out of the device.
    In addition to instructions here, the manufacturer instructed to boot computer once battery is removed boot up using ac power. This might only apply to Macs. Power down and install battery. Let the battery drain. Shut down. Then charge the computer for12 hours to fully activate the lithium ion to reach full capacit. Also drain battery at least three times to reach maximum capacity.
    Tindara Certo - crwdns2934203:0crwdne2934203:0
Drew Lawson
crwdns2935283:004/09/18crwdne2935283:0
387 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team S3-G2, Rowley Spring 2018 crwdns2935289:0Eastern Washington University, Team S3-G2, Rowley Spring 2018crwdne2935289:0
EWU-ROWLEY-S18S3G2
Is there a part to order if the solder gives from the mother board connection peice. My cable came up from the board with connection still attached
wolf brown - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 7,438
