This guide will describe how to remove the battery on the Asus Q551L. This is a fairly simple procedure that requires only a screwdriver. The battery may need to be replaced if it cannot hold a charge, experiences heating issues, or simply ceases to function. Make sure your device is turned off and unplugged before removing the battery.
Unscrew the 10 screws around the edge of the back panel. Eight of the screws are 0.0793mm T5 , two of them are 0.0793 JIS #0.
Use the plastic opening tool to pry the back panel off the base of the laptop.
Unscrew the four screws to remove the battery.
Un-clip both wire clips on the upper and right side of the battery.
Lift the battery out of the device.
Is there a part to order if the solder gives from the mother board connection peice. My cable came up from the board with connection still attached
