Asus Q534U CPU Fan/Heat Sink Replacement
  1. Asus Q534U CPU Fan/Heat Sink Replacement, Back Case Removal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure the device is turned off and unplugged from the charger.
    • Use a T5 screwdriver to remove all 10 screws that secure the bottom cover.
    • Pull off the back cover of the laptop.
    • A pry tool may be needed to pull off the back cover.
  2. Asus Q534U CPU Fan/Heat Sink Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Q534U CPU Fan/Heat Sink Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Wedge an opening tool under the battery's bundled cable connector, and gently pry the connector up and to disconnect the battery.
    Step 2 I did not realize that the pictures to the right were enlarged for easier understanding of the step. Great walk through even a 66 year old man could understand and do it. Got the I Fix It tools which made opening the case and working with the tiny screws a breeze.
    Steven CARTER - crwdns2934203:0crwdne2934203:0
  3. Asus Q534U CPU Fan/Heat Sink Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Q534U CPU Fan/Heat Sink Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up the black tab next to the silver ribbon cable.
    • Pull lightly on the blue tabs until the silver cable is free.
    Before doing anything here I would highly recommend disconnecting the buttery. I didn't do it myself at the beginning and when removing this ribbon cable I caused sparks going off the right connector.
    Alex Vasko - crwdns2934203:0crwdne2934203:0
    Great suggestion, Alex! This guide should now reflect a safer and more accurate procedure. Thanks for the heads-up.
    Richard -
    To clarify: you need to flip up the black plastic tab of the recepticle, not the cable. Then don't pull the blue tab up, you need to angle it up just a little bit, about 15 degrees, then slide the cable out.
    Gaspard van Ko - crwdns2934203:0crwdne2934203:0
  4. Asus Q534U CPU Fan/Heat Sink Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the 5 marked screws.
    • Gently remove the battery.
    • Do not bend or puncture the laptop's lithium-polymer pattery.
  5. Asus Q534U CPU Fan/Heat Sink Replacement, CPU Fan/Heat Sink: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Q534U CPU Fan/Heat Sink Replacement, CPU Fan/Heat Sink: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the iFixit opening tool, gently pry the CPU fan connector out of the socket.
  6. Asus Q534U CPU Fan/Heat Sink Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Q534U CPU Fan/Heat Sink Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Move the black cable located around the CPU fan out of the holder.
    • Remove the following 9 screws:
    • Three Phillips screws
    • Six Phillips screws
    • Make sure not to mix up both types of screws.
    • Gently pull vertically on the CPU fan/ heat sink assembly until it is free.
    • Before placing a new CPU fan/heat sink assembly, the CPU and GPU surfaces must be cleaned off and thermal compound must be reapplied.
mmedina
crwdns2935283:004/07/16crwdne2935283:0
809 crwdns2915208:0crwdne2915208:0
Is it possible to replace the fan only without removing the full heatsink or is it fused together as one unit?
Bork Bois - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 3,065
