This guide will go over the process of removing and replacing the CPU fan and heat sink assembly.
Use a T5 screwdriver to remove all 10 screws that secure the bottom cover.
Pull off the back cover of the laptop.
Wedge an opening tool under the battery's bundled cable connector, and gently pry the connector up and to disconnect the battery.
Lift up the black tab next to the silver ribbon cable.
Pull lightly on the blue tabs until the silver cable is free.
Use a Phillips #00 screwdriver to remove the 5 marked screws.
Gently remove the battery.
Using the iFixit opening tool, gently pry the CPU fan connector out of the socket.
Move the black cable located around the CPU fan out of the holder.
Remove the following 9 screws:
Three Phillips screws
Six Phillips screws
Gently pull vertically on the CPU fan/ heat sink assembly until it is free.
Is it possible to replace the fan only without removing the full heatsink or is it fused together as one unit?
