Asus Q504UA-BHI5T13 Battery Replacement
  1. Asus Q504UA-BHI5T13 Battery Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Ensure that the laptop is off so you do not shock yourself.
    Thank you very much for the walk through video, it helped me a lot.
    Coastie228 - crwdns2934203:0crwdne2934203:0
  2. Asus Q504UA-BHI5T13 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the T5 Torx screwdriver to remove the ten 1mm screws located around the back cover.
  3. Asus Q504UA-BHI5T13 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two rubber pads nearest to you using the metal spudger.
    The two pads on the hinge side.
    vendor02 - crwdns2934203:0crwdne2934203:0
  4. Asus Q504UA-BHI5T13 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the Phillips #0 screwdriver to remove the two 4mm screws that are under the rubber pads.
  5. Asus Q504UA-BHI5T13 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert any of the plastic opening tools into the seam to separate the back cover (it is recommended to start at the corner of the hinges). If you did it right, then the cover should pop off.
    • Be careful as you may damage the tabs.
    Another good place to start is at the USB port near the SD card slott. Work toward the hinge first, then back down the short side. There are 5 strong tabs on each short side, and several weaker tabs on the front and between the hinges. The tabs are attached to the bottom. Once one short side is nearly free and the front seam is not totally closed, then try pushing the bottom toward the free short side (at most 1/2 mm) which can make the other tabs easier to “pop”.
  6. Asus Q504UA-BHI5T13 Battery Replacement, Battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the back cover is removed, have the laptop facing upside down with the hinges facing toward you.
  7. Asus Q504UA-BHI5T13 Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the Phillips #0 screwdriver to remove the five 4mm screws around the battery.
  8. Asus Q504UA-BHI5T13 Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Q504UA-BHI5T13 Battery Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the small plastic opening tool to remove the ZIF Connector on the right side of the battery.
  9. Asus Q504UA-BHI5T13 Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Q504UA-BHI5T13 Battery Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery from the device.
Brielle
crwdns2935283:010/02/17crwdne2935283:0
205 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S10-G4, Thompson Fall 2017 crwdns2935289:0USF Tampa, Team S10-G4, Thompson Fall 2017crwdne2935289:0
USFT-THOMPSON-F17S10G4
Anyone know where to purchase this battery. I’ve ordered off ebay only to get a non-fitting battery and have scoured the internet only to come up empty handed. Any help appreciated.
Rick Grinstead - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 52
crwdns2942667:0crwdne2942667:0 5,667
