Asus Q504UA-BHI5T13 Back Panel Replacement
  1. Asus Q504UA-BHI5T13 Back Panel Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Ensure that the laptop is off so you do not shock yourself.
  2. Asus Q504UA-BHI5T13 Back Panel Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the T5 Torx screwdriver to remove the ten 1mm screws located around the back cover.
  3. Asus Q504UA-BHI5T13 Back Panel Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two rubber pads nearest to you using the metal spudger.
  4. Asus Q504UA-BHI5T13 Back Panel Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the Phillips #0 screwdriver to remove the two 4mm screws that are under the rubber pads.
  5. Asus Q504UA-BHI5T13 Back Panel Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert any of the plastic opening tools into the seam to separate the back cover (it is recommended to start at the corner of the hinges). If you did it right, then the cover should pop off.
    • Be careful as you may damage the tabs.
Johnathan Teav
crwdns2935283:010/02/17crwdne2935283:0
456 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S10-G4, Thompson Fall 2017 crwdns2935289:0USF Tampa, Team S10-G4, Thompson Fall 2017crwdne2935289:0
USFT-THOMPSON-F17S10G4
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 1,087
