If your RAM needs to be replaced then this guide will show you how to properly do so.
Use a Phillips #0 screwdriver to remove the ten 3mm Phillips head screws on the base of the laptop.
Use the spudger to pry open the rear cover at either hinge.
Grab the cover with your fingers and gently lift it away from the board.
Press down the metal tabs on both sides of the RAM.
