If your laptop is having issues with batter life, your batter may be malfunctioning. In this guide, we will show you how to replace the battery.
Use a Phillips #0 screwdriver to remove the ten 3mm Phillips head screws on the base of the laptop.
Use the spudger to pry open the rear cover at either hinge.
Grab the cover with your fingers and gently lift it away from the board.
Remove the five silver 4mm Phillips #0 screws holding the battery to the laptop.
Using the spudger, carefully remove the power cable connecting the battery to the rest of the laptop.
Once the screws and cable are removed, carefully lift the battery from the laptop.
