This guide will walk users through the disassembly of their Asus device.
Use a Phillips #0 screwdriver to remove the ten 3mm Phillips head screws on the base of the laptop.
Use the spudger to pry open the rear cover at either hinge.
Grab the cover with your fingers and gently lift it away from the board.
I got one of these model, how much RAM is the maximum amount supported?
