Asus Q325U Motherboard Replacement
  1. Asus Q325U Motherboard Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus Q325U Motherboard Replacement, Back Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus Q325U Motherboard Replacement, Back Panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the ten 5mm screws using a T5 Torx screwdriver.
  2. Asus Q325U Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus Q325U Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus Q325U Motherboard Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the back panel upward using the suction tool.
  3. Asus Q325U Motherboard Replacement, SSD: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Q325U Motherboard Replacement, SSD: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove one 2mm screw on top of the SSD using a Phillips #1 screwdriver.
  4. Asus Q325U Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Q325U Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully slide and lift the SSD to remove it.
  5. Asus Q325U Motherboard Replacement, Battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Q325U Motherboard Replacement, Battery: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the seven 5mm screws around the battery using a Phillips #00 screwdriver.
  6. Asus Q325U Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Q325U Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #000 screwdriver, remove the two 3mm screws on top of the orange battery connector.
    In my case, there were no screws, but two posts to be placed in corresponding slots in the replacement battery. So no need for the Philips #000.
    Emmanuel Francois - crwdns2934203:0crwdne2934203:0
  7. Asus Q325U Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Q325U Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the battery out from the laptop.
    This was great! Thanks for publishing. One thing. The battery connection was not held by two 000 screws. The plastic connector simply clicked in place, so I carefully lifted it with a tool
    Joe Creighton - crwdns2934203:0crwdne2934203:0
  8. Asus Q325U Motherboard Replacement, Copper Plate: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Q325U Motherboard Replacement, Copper Plate: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the six 3mm screws using a Phillips #00.
  9. Asus Q325U Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Q325U Motherboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the plastic opening tool to lift up the edge. Pull upward on the edge.
  10. Asus Q325U Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Q325U Motherboard Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • On the other side of the plate, remove the tape.
  11. Asus Q325U Motherboard Replacement, CPU Fan: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Q325U Motherboard Replacement, CPU Fan: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three 3.7 mm screws using a Phillips #00 screwdriver.
  12. Asus Q325U Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Detach the black wire and plug shown using a tweezer.
  13. Asus Q325U Motherboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grab CPU fan by its edge and gently pull upwards to remove.
  14. Asus Q325U Motherboard Replacement, Motherboard: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Q325U Motherboard Replacement, Motherboard: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Halberd Spudger
    $2.99
    • Remove the first connection wire by pulling the small back loop with the Halberd Spudger.
  15. Asus Q325U Motherboard Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus Q325U Motherboard Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus Q325U Motherboard Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the small black tab of the orange connector with your fingers or a plastic opening tool.
    • Remove the orange connector by pulling with tweezers.
  16. Asus Q325U Motherboard Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus Q325U Motherboard Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus Q325U Motherboard Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the small black tab on the white plastic piece of the touch pad connector with a spudger.
    • Remove the touch pad connector by pulling with tweezers.
  17. Asus Q325U Motherboard Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus Q325U Motherboard Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus Q325U Motherboard Replacement: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the black tab on the long white plastic piece of the thick blue band.
    • Remove the thick blue band by pulling.
  18. Asus Q325U Motherboard Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus Q325U Motherboard Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus Q325U Motherboard Replacement: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two Phillips #000 screws on the metal connector above the thick orange band.
    • Lift up the thick orange band.
  19. Asus Q325U Motherboard Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus Q325U Motherboard Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus Q325U Motherboard Replacement: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently lift up the two smallest connectors using your fingers or a plastic opening tool.
  20. Asus Q325U Motherboard Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Q325U Motherboard Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up the black hinge of the connector using a plastic opening tool.
    • Remove the connector using a tweezer.
  21. Asus Q325U Motherboard Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus Q325U Motherboard Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus Q325U Motherboard Replacement: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull up the tap of the biggest connector using your fingers.
    • Lift the gold hinge using a plastic opening tool.
    • Lift the connector up with your fingers to remove.
  22. Asus Q325U Motherboard Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Q325U Motherboard Replacement: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 4.8 mm screws using a Phillips #00 screwdriver.
  23. Asus Q325U Motherboard Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Q325U Motherboard Replacement: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slightly open up the laptop. This will lift up the hinge at the corner and free the motherboard.
  24. Asus Q325U Motherboard Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Q325U Motherboard Replacement: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the motherboard away from the corner to remove.
Miriam Miller
crwdns2935283:001/24/19crwdne2935283:0
714 crwdns2915208:0crwdne2915208:0
Can you help me identify which of those is the webcam conector? I hava a faulty webcam and my guess is that it is a physical conection problem.
pgmolin - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 978
