Asus Q302UA-BHI5T20 Motherboard Replacement
  1. Asus Q302UA-BHI5T20 Motherboard Replacement, Motherboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Q302UA-BHI5T20 Motherboard Replacement, Motherboard: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place laptop upside down.
    • Use a Phillips #0 screwdriver to remove the ten 1 cm case screws from the bottom of the laptop.
  2. Asus Q302UA-BHI5T20 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Q302UA-BHI5T20 Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the CPU fan by carefully pulling out the small black connector(plug) located in the corner (redbox)
    • Use a Phillips #0 screwdriver to remove the three 4 mm screws that secure the fan.
  3. Asus Q302UA-BHI5T20 Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Q302UA-BHI5T20 Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the four 3 mm screws that secure the heat sink.
  4. Asus Q302UA-BHI5T20 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Q302UA-BHI5T20 Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #0 screwdriver to unscrew the five 5 mm screws that secure the battery.
    • Disconnect the battery's bundled cable connector and lift the battery up and out of the laptop.
  5. Asus Q302UA-BHI5T20 Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the WiFi antennae by gently pulling up at each antenna's connector. Use a spudger to help lift each antenna free from the WiFi card if needed.
  6. Asus Q302UA-BHI5T20 Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Speaker Data Connector.
    • Gently pry out.
  7. Asus Q302UA-BHI5T20 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull up the ZIF connector tabs and then pull out the ribbon cables.
    • For the orange boxes, you pull the little black tab up to remove connector.
    • A little extra force might need to be used for this step.
  8. Asus Q302UA-BHI5T20 Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Display Connector.
    • Pull tab, and pull up.
  9. Asus Q302UA-BHI5T20 Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Q302UA-BHI5T20 Motherboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the two 6 mm screws.
    • After removing the screws, lift the hinge up slightly to give clearance to the motherboard.
    • Some force is required to lift the metal hinge support up. To lift, pull up and rotate as you're pulling up.
  10. Asus Q302UA-BHI5T20 Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Q302UA-BHI5T20 Motherboard Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the six 4 mm screws.
    • Gently pick up the motherboard without applying any unnecessary force.
Dymon Alfred
crwdns2935283:009/20/17crwdne2935283:0
300 crwdns2915208:0crwdne2915208:0
University of North Texas, Team S5-G4, Thomas Fall 2017 crwdns2935289:0University of North Texas, Team S5-G4, Thomas Fall 2017crwdne2935289:0
UNT-THOMAS-F17S5G4
crwdns2942667:0crwdne2942667:0 578
