With the phone facing down, look at the bottom right side corner and there should be a groove. Use a plastic opening tool and lift up to remove outside cover.
Lift the battery out from the top of the device.
Around the perimeter, there should be 10 2 mm T5 Torx screws. Take them out.
Remove the cover.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Remove speaker with standard tweezers to minimize damage, and replace.
Detach the black connector on the left hand side of the motherboard.
Disconnect silver connector from the motherboard. It is located on the left hand side above the black connector.
Remove motherboard and replace screen.
