unscrew these two screws to remove the coverage
unscrew these four screws to take out the case with the hard drive disk
pull the strap to remove the hard drive's case
unscrew the four screws of the case to remove the hard drive out of that case
put the new hard drive or SSD, respectively in the case and fix the screws again (the HDD/SDD will only fit in the case in one way)
slip the case to the right to plug in the HDD/SDD again
crwdns2935219:0crwdne2935219:0
