Asus P2530U/P2540U Hard Drive/SSD Replacement
  1. Asus P2530U/P2540U Hard Drive/SSD Replacement, Unlock Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus P2530U/P2540U Hard Drive/SSD Replacement, Unlock Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus P2530U/P2540U Hard Drive/SSD Replacement, Unlock Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • On the underside of the device, slide the battery lock on the right-hand side towards the right.
    • Slide the lock on the left-hand side to the left and hold it there.
  2. Asus P2530U/P2540U Hard Drive/SSD Replacement, Remove battery.: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus P2530U/P2540U Hard Drive/SSD Replacement, Remove battery.: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Keeping the left and right locks disengaged, pull the battery outwards in the direction of the screen hinge.
  3. Asus P2530U/P2540U Hard Drive/SSD Replacement, Remove cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #00 screwdriver (or comparatively small screwdriver), remove both screws from the drive/ram bay cover.
  4. Asus P2530U/P2540U Hard Drive/SSD Replacement, Remove cover (cont.): crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull downwards on the cover- this may require a fair amount of force.
  5. Asus P2530U/P2540U Hard Drive/SSD Replacement, Unscrew drive cage: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the same screwdriver from before, unscrew each of the 4 screws holding the drive cage in place.
    • Take care not to drop the screws inside the machine, as this could damage components.
  6. Asus P2530U/P2540U Hard Drive/SSD Replacement, Remove drive cage: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the drive cage to the left to disconnect the drive from the device.
  7. Asus P2530U/P2540U Hard Drive/SSD Replacement, Remove drive cage (cont.): crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the black pull tab, pull the drive cage up and out of the device.
  8. Asus P2530U/P2540U Hard Drive/SSD Replacement, Remove drive from cage: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus P2530U/P2540U Hard Drive/SSD Replacement, Remove drive from cage: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus P2530U/P2540U Hard Drive/SSD Replacement, Remove drive from cage: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the same screwdriver from earlier, unscrew the 4 screws holding the drive in the cage
    • Slide the drive out of the cage
To reassemble your device, follow these instructions in reverse order. Take care to insert the drive into the drive cage in the correct orientation, so the pins on the drive line up with the connector on the device.
Kiwiboiii
crwdns2935283:007/22/22crwdne2935283:0
241 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 770
