Replace your defective motherboard to allow other hardware components to be able to communicate with each other effectively again.
Use the metal spudger to gently pry open the back of the Nexus Player.
Use a PH1 Philips-head screw driver to unscrew the four 8 mm screws holding the shield in place.
Once screws are removed, simply lift the shield away.
Remove the 5 mm screw using the PH1 Phillips-head screwdriver to be able to remove the motherboard.
After the screw is removed, lift the motherboard out of the frame.
