Asus N56VM Motherboard Replacement
  1. Asus N56VM Motherboard Replacement, Remove battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery and the AC power
  2. Asus N56VM Motherboard Replacement, Remove bottom cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus N56VM Motherboard Replacement, Remove bottom cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the M2x4 screw of the bottom cover
    • Remove the bottom cover by sliding it downwards
  3. Asus N56VM Motherboard Replacement, Optical drive: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screw holding the optical drive
  4. Asus N56VM Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull out the optical drive
  5. Asus N56VM Motherboard Replacement, Hard Disk: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus N56VM Motherboard Replacement, Hard Disk: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screws
    • Remove the 3 M2x10 screws
    • Remove the one M2x4 screw
  6. Asus N56VM Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull the hard disk to the left
  7. Asus N56VM Motherboard Replacement, RAM: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two RAM modules
    • Pop them out gently
    • Make sure you are electrostatically not loaded
  8. Asus N56VM Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Detach the two cables from the wireless module
  9. Asus N56VM Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus N56VM Motherboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove all screws from the bottom cover
    • Remove 7 M2x10 screws
    • Remove 3 M2x4 screws
    • Remove 2 small screws
  10. Asus N56VM Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus N56VM Motherboard Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus N56VM Motherboard Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the lid of the notebook
    • Use a plastic opening tool to pry the bottom case
    • Be very careful when opening so that the cables in the case are not severed.
  11. Asus N56VM Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The motherboard is still connected to the bottom case by several cables, so don't try to remove it entirely just yet.
    • Hold the upper part with one hand, and use your other hand to disconnect the black&white cable (antenna for the wifi card)
    The black and white cables you see in this image are the antennae for the wifi card.
    This wifi card is connected to the m.2 port.
    If you get an external faster wifi adapter you can use the m.2 port for an additional SSD up to 60mm in length.
    ssg60 - crwdns2934203:0crwdne2934203:0
    The other cable connected to the motherboard is for the display.
  12. Asus N56VM Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Continue to hold the upper part with one hand, and use your other hand to disconnect the black ribbon cable
    • Remove the upper part with the motherboard
  13. Asus N56VM Motherboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus N56VM Motherboard Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • This component is attached by a cable to the lower side of the motherboard therefore it is advised to remove it.
    • Remove the two screws holding the VGA IC
    • Lift the IC
  14. Asus N56VM Motherboard Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus N56VM Motherboard Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus N56VM Motherboard Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the cable by first lifting the black holder and then removing the cable
  15. Asus N56VM Motherboard Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the white cable simply by pulling it out from the connector
  16. Asus N56VM Motherboard Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus N56VM Motherboard Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus N56VM Motherboard Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the touchpad cable by first lifting the black holder
  17. Asus N56VM Motherboard Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus N56VM Motherboard Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus N56VM Motherboard Replacement: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two keyboard cables by first pulling out the black holders. After that the cables are released
  18. Asus N56VM Motherboard Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus N56VM Motherboard Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four screws holding the motherboard
    • Remove the screw holding the fan
    • Pry out the plastic thing holding the motherboard in place
Stanky
crwdns2935283:007/08/17crwdne2935283:0
1,268 crwdns2915208:0crwdne2915208:0
Can you please help me locate the gpu VRM on the motherboard? My gpu is faulty and needs to be rebonded, so I wanna permanently disable it.
Coll Student - crwdns2934203:0crwdne2934203:0
Sorry, I can’t help you with that
Stanky -
crwdns2936753:030crwdne2936753:0 33
crwdns2942667:0crwdne2942667:0 3,465
